Why Steel Corrosion Is More Than Just Rust
Most people recognize corrosion by its visible symptom: rust. However, rust is only the surface evidence of a much larger process. Corrosion is an electrochemical reaction that gradually consumes steel, reduces structural capacity, compromises connections, and creates long-term maintenance obligations. For owners, engineers, and asset managers, corrosion is not primarily a cosmetic issue. It is a durability, safety, and lifecycle cost concern that affects the long-term performance of infrastructure and facilities.
Understanding how corrosion develops is essential when selecting an appropriate steel protection strategy. This article explains the mechanisms behind atmospheric corrosion, examines how protective coating systems interrupt those processes, and discusses why hot-dip galvanizing provides long-term corrosion protection in a wide range of environments.
What Happens During Atmospheric Corrosion?
Atmospheric corrosion occurs when moisture on a steel surface creates the conditions necessary for electrochemical reactions to occur. A thin film of water from rainfall, condensation, fog, or hygroscopic contaminants acts as an electrolyte, allowing different areas of the steel surface to behave as microscopic anodes and cathodes.
At anodic sites, iron dissolves into the electrolyte as ions. At cathodic sites, oxygen reduction reactions consume electrons and alter the local chemistry of the moisture film. Together, these reactions drive the corrosion process and ultimately produce the iron oxides and oxyhydroxides commonly recognized as rust.
The rate of atmospheric corrosion depends largely on three factors:
- Time-of-wetness
- Oxygen availability
- Surface chemistry
Time-of-wetness is particularly important because corrosion reactions require a conductive moisture layer. As steel remains wet for longer periods, the electrochemical process can continue. Conversely, extended dry periods interrupt ionic transport and slow corrosion activity.
Environmental contaminants also influence corrosion rates. Chlorides from marine environments and deicing salts increase surface conductivity and promote moisture retention. Industrial pollutants such as sulfur dioxide (SO₂) and nitrogen oxides (NOx) can alter surface pH and accelerate deterioration under certain conditions. For more information on environmental corrosion classifications see AGA article, HDG Corrosion Rates for ISO Categories C1-C5/X.
Research has shown that atmospheric corrosion is highly dependent on the interaction between moisture, oxygen, and dissolved contaminants. As these factors change, corrosion rates and corrosion-product formation can vary significantly from one environment to another.
Why Corrosion Often Concentrates in Specific Areas
Corrosion seldom progresses uniformly across an entire steel surface. Instead, localized attack frequently develops in areas where moisture and contaminants accumulate.
Common examples include:
- Lap joints
- Bolted connections
- Crevices
- Weld details
- Areas with poor drainage
- Overlapped surfaces
Uniform surface rust may appear extensive while causing relatively little section loss. By contrast, localized pitting can remove significant material from a small area with limited visible evidence.
For engineers and inspectors, identifying environments and details that encourage localized corrosion is often more important than assessing the overall amount of rust visible on a structure.
