Galvanized coatings are formed by a chemical process during which steel and zinc metallurgically bond, forming a series of corrosion-inhibiting, highly abrasion-resistant zinc/iron alloy layers.
Galvanized coatings are specified for their corrosion resistance. While a gray or matte appearance may occur, the corrosion protection afforded is no different than that provided by shinier galvanized coatings. The corrosion resistance of matte coatings, mil for mil, is equal to the more typical bright, shiny galvanized coating.
Different2 72
Variation in Finish
When possible, the galvanizer should be advised of the grade of steel selected in order to determine whether to make accommodations in the galvanizing process. Though most ferrous materials can be hot-dip galvanized, the chemical composition of the material affects the characteristics of the galvanized coating.
Steel compositions vary depending on strength and service requirements. Trace elements in the steel, such as silicon and phosphorus, affect the galvanizing process as well as the structure and appearance of the galvanized coating. For example, certain elements present in the steel may result in a coating composed almost entirely of zinc-iron alloy layers with little or no free zinc layer.
Pipe Dull Vs Shiny
The chemistry of the steel being galvanized influences the galvanized coatings appearance. Galvanized coatings on steels with common chemistries are typically shinier than are coatings on reactive steels, which tend to produce matte gray coatings.
Additionally, high-strength steel chemistries for steels with ultimate tensile strength of 150 ksi (1100 MPa) or more may experience hydrogen embrittlement of the steel. Galvanized coatings are specified for their corrosion resistance. While a gray or matte appearance may occur, the corrosion protection afforded is no different than that provided by shinier galvanized coatings. The corrosion resistance of matte coatings, mil for mil, is equal to the more typical bright, shiny galvanized coating.
Diffsteel2
Related article - Evaluating Steel Chemistry Prior to Galvanizing
