What steps are involved in progressive dipping an item too large for the kettle?
Progressive dipping is oftentimes a viable option for items too large for the kettle. However, extra steps must be taken to ensure both ends of the item going into the kettle are freshly fluxed. The AGA has recently put together a series of photographs that go through the steps typically involved in the progressive dipping process.
The item progressive dipped in this example is a large, square plate in a galvanizing plant with a monorail crane. It should be noted that differing plant configurations may affect the steps involved and every galvanizer does things a little differently. As long as the item is fully coated, and meets the standards of ASTM A123, there is not necessarily a right or wrong way to progressive dip. This article covers the steps involved in a general sense.
1 Prog Dip
The item is submerged at least halfway in the kettle; up until this point everything regarding surface preparation has been performed according to the plant’s standard operating procedures.
2 Prog Dip
The item leaves the kettle at least halfway galvanized.
3 Prog Dip
Next, the item is taken to the finishing area where the crew attaches chains to the galvanized (bottom) side.
4 Prog Dip
The item is then laid down and chains and other rigging materials are removed from the ungalvanized side.
5 Prog Dip
The item is picked back up with the ungalvanized end downwards and is taken backward on the crane past the galvanizing kettle.
6 Retouched Prog Dip
The item is taken back to the pretreatment area and the ungalvanized portion is either cleaned and fluxed, or fluxed-only (depending on variations in the galvanizer's process).
7 Prog Dip
Once fluxing is complete, the item is taken back to the kettle to finish galvanizing.
8 Retouched Prog Dip
The bottom half of the item is submerged in the kettle, allowing the iron and zinc to react with one another, growing the galvanized coating.
12 Retouched Prog Dip
The item is now fully galvanized and continues on to the cooling and inspection area.
