One of my customers has asked me to galvanize his product according to ISO 1461. Is this specification different from ASTM A123? And, if so, what are the differences?
*Updated in 2022
Summary
International Standards Organization ISO 1461, Hot Dip Galvanized Coatings on Fabricated Iron and Steel Articles - Specifications and Test Methods, is a general galvanizing specification. Hot-dip galvanizing to A123 will typically lead to a final quality which meets or exceeds ISO 1461.
This article provides a basic overview of the similarities and differences between ISO 1461 and A123 as they relate to coating thickness, appearance, repairs, adhesion, inspection, and sampling. It is not intended to be used as an exhaustive guide on the differences in terms of inspection requirements or contractual obligations when substituting one specification for the other.
Scope of Specifications
ISO 1641 Scope
Ordering Information
The purchaser must provide the following:
ISO 1641 Ordering Information
Base Metal Considerations
ISO 1641 Materials
Zinc and The Galvanizing Bath (Zinc Melt)
ISO 1641 Zinc Bath
Coating Requirements
Coating Thickness for Articles That Are Not Centrifuged
The differences in minimum average coating thickness for most steel articles are small. In the specification, the ISO minimum coating thickness requirements are summed up into one table, which does not mention coating grades and does not require the user to reference two tables as with ASTM A123. Also, the ISO1461 specification lists minimum local coating thickness to which any one measurement must meet. These are 0.4-0.6 mils thinner than the minimum average coating thickness. In the ASTM specifications, only ASTM A153 has such minimum local thickness coating listed for castings and fasteners. Rolled, pressed and forged articles referred to ASTM A153 also have minimum local coating thickness; these articles are not specifically mentioned in the ISO specification.
A comparison of the standards finds they are very similar, with the ASTM Specs typically requiring more coating thickness on most types and thickness of steel.
ISO 1641 vs A123
For further comparison, a summary of the ASTM A123 coating thickness requirements is provided below.
Table 1: Minimum Average Coating Thickness Grade by Material Category
All Specimens Tested, Steel Thickness Range (Measured) in. [mm]
Material Category<1/16
[<1.6]
>1/16 to <1/8
[>1.6 to <3.2]
>1/8 to 3/16 [>3.2 to < 4.8]
>3/16 to <1/4
[>4.8 to <6.4]
>1/4 to <5/8
[>6.4 to <16.0]
>5/8
[>16.0]
Strip and Bar4565757575100
Plate4565757575100
Pipe & Tubing454575757575
Wire355060658080
Reinforcing Bar--------100100
Forgings and Castings----
100100100
Resolving Concerns When Galvanizing Low Reactivity Steels
Steels with very low levels of silicon and aluminum-killed steels regularly present a challenge in developing a galvanized coating that meets the thickness requirements of the galvanizing specifications. To address these concerns, both galvanizing standards provide guidance to address occasional instances where normal coating thickness requirements cannot be achieved when galvanizing steels with low reactivity.
ISO 1641 Low Reactivity Steels
Coating Thickness for Centrifuged Articles
The ISO 1461 standard incorporates the ASTM equivalent of A153 regarding centrifuged articles into ISO 1461. It is more difficult to compare the ISO 1461 category requirements and ASTM A153 category requirements side by side for articles not centrifuged. This is because the ASTM material categories are defined through a combination of part size and steel thickness. A comparison of the tables is provided below:
A153 table
Adhesion/Adherence
ISO 1641 adhesion
Sampling & Inspection
Inspection Lots
ISO 1641 lots
Control Sample Size vs. Lot Size
ISO 1641 test articles
Reference Areas for Coating Thickness Inspection
For each reference area, five or more measurements are made at widely dispersed points to represent the entire surface area of the test specimen.
ISO 1641 reference areas
Test Methods
ISO 1641 test methods
Repairs
ISO 1641 repairs
Certificate/Declaration
ISO 1641 certificate
