What welding electrodes are recommended for fixtures, kettle repair, or fabrications?
Selecting the proper welding material is critical for long-lasting kettle repairs, fabricating equipment used to support hot-dip galvanizing operations (overhead fixtures, racks, and baskets), as well as before galvanizing to reduce coating thickness over the welds. Molten zinc is very aggressive to steel and weld materials, so selecting the wrong material can cause the weld to erode in a matter of weeks and lead to excessive and costly repairs. To prevent rapid attack or corrosion of the weld material, it is necessary to use welding rods that will not be quickly consumed by the zinc, but instead corrode at a similar rate to the base metal.
Fig1
Figure 1: AGA Welding Rod Study Update: 1, 3 and 6 month test samples and control sample.
Twenty five years ago, the AGA evaluated the corrosion resistance of various weld materials to molten zinc and established a list of six materials recommended for kettle repair and the fabrication of fixtures or racks. Unfortunately, some of the weld materials that were tested previously are no longer being produced today. To update the existing list, a new set of welding electrodes was tested in 2017 upon consultation with Lincoln Electric (Figure 1). The scope was expanded beyond stick welding (SMAW) rods and flux-cored arc welding (FCAW) wires, and now includes a submerged arc welding (SAW) electrode for faster weld deposition. These materials were immersed in a galvanizing kettle of molten zinc and some were removed at 1 month, 3 month, and 6 month test periods. The updated list of recommended welding materials in Table 1 includes the new welding materials from the updated study which showed similar weight loss to the unwelded control sample or base metal. Generally, it was determined that weld materials with a silicon content less than 0.25% tend to work well in contact with the molten zinc.
TABLE 1: RECOMMENDED WELDING MATERIALS FOR KETTLE REPAIRS, FIXTURES, RACKS AND BASKETS (UPDATED 2017)
Welding ProcessLincoln Electric Welding ElectrodeAWS DesignationSilicon (Weight %)
SMAW
Jetweld 2
Fleetwood 35 LS
E6027
E6011
0.22-0.26%
0.10-0.18%
SAWL60-860F6A2-EL120.24%
FCAW
*NR-203 NiC+
NR 203 MP
NR 233
NR 311
E71T8-K2
E71T-8J
E71T-8
E70T-7
0.06%
0.22-0.26%
0.19-0.20%
0.12-013%
* Welding wire lost prior to fabrication during the study; it is recommended to use a test plate before use.
Figure 2    Increased  Thickness In  Weld  Area
Figure 2: Increased Thickness in Weld Area
Table 1 can also be used to specify welding materials that are suitable for use during fabrication where welding is performed before hot-dip galvanizing. When the selected welding rod material is more reactive than the surrounding steel, a different appearance over the weld can be expected which is often duller in appearance, rougher, and thicker (Figure 2). However, the latest results of the Welding Rod Study indicate that the Silicon content (% Si) of the weld material does not necessarily follow the pattern of galvanizing reactivity as shown by the Sandelin Curve. Although the Sandelin curve is a useful chart for determining the reactivity of steel to be hot-dip galvanized, it may not be a useful metric when trying to match weld material reactivity to base metal reactivity to achieve similar coating thickness and appearance. Where unsure, the welding materials listed in Table 1 can be used to reduce coating thickness over the welds, resulting in a more uniform appearance overall.
For more details and an explanation of the test method and results, refer to the Galvanizing Note entitled Welding Electrodes Resistant to Molten Zinc Attack.
See Also:
