The specification to determine the presence of chromate on zinc surfaces is ASTM B201. This test involves placing drops of a lead acetate solution on the surface of the product, waiting 5 seconds, and then blotting it gently. If this solution creates a dark deposit or black stain, then there is unpassivated zinc present. A clear result indicates the presence of a chromate passivation coating.
