Specifying Galvanized Structural Pipe and Tube
Which is the correct material category in ASTM A123/A123M to specify pipe or tubing used for structural purposes?
This is a common question among specifiers, and the confusion is understandable considering it seems like pipe can fall into two categories in ASTM A123/A123M Structural Shapes and Plate or Pipe and Tubing. This distinction is important because some steel thickness ranges for the two categories call for different coating thickness minimums. See the bolded line in Table 1 from ASTM A123/A123M.
ASTM A123 Table 1: Minimum Average Coating Thickness (μm) by Material Category
Material Category | All Specimens Tested- Steel Thickness Range (Measured), in. (mm) | |||||
<1/16 [<1.6] | >1/16 to <1/8 [>1.6 to <3.2] | >1/8 to 3/16 [>3.2 to < .8] | >3/16 to <1/4 [>4.8 to <6.4] | >1/4 to <5/8 [>6.4 to <16.0] | >5/8 [>16.0] | |
Structural Shapes | 45 | 65 | 75 | 75 | 100 | 100 |
Strip and Bar | 45 | 65 | 75 | 75 | 75 | 100 |
Plate | 45 | 65 | 75 | 75 | 75 | 100 |
Pipe and Tubing | 45 | 45 | 75 | 75 | 75 | 75 |
Wire | 35 | 50 | 60 | 65 | 80 | 80 |
Reinforcing Bar | - | - | - | - | 100 | 100 |
The correct material category to specify pipe or tubing used for structural purposes is the Pipe and Tubing category because although it serves a structural role, it is still a pipe or tube product.
Coating thickness minimums in ASTM galvanizing specifications are not randomly selected; rather, they come from experience of galvanizing many different steel members and observing the common coating thicknesses achieved on those members. Different material categories in ASTM A123/ A123M often have different steel chemistry when compared to other material categories.
One such difference is pipe and tubing is often aluminum killed rather than silicon-killed, so there is much less or nearly no silicon in pipe and tubing. Because silicon is one of the catalysts for the galvanizing reaction, pipe and tubing often develops a thinner hot-dip galvanized coating because there is less available to catalyze the metallurgical reaction in the galvanizing process.
