Hydrogen Embrittlement
Hydrogen embrittlement occurs when steel cracks due to hydrogen that is trapped between the grains of the steel. Although steel commonly absorbs hydrogen during the hot-dip galvanizing process, it is usually expelled due to the temperature of the zinc in the galvanizing kettle. In some cases, however, the grain size of the steel is too small to allow release of atomic hydrogen. This can later cause cracking due to increased stress at the location of the hydrogen between the grains. Grains of steels with a tensile strength below 170 ksi (170,000 psi) are usually big enough to allow escape of hydrogen, but for steels having a tensile strength of 170 ksi or greater, there is a potential for hydrogen to remain trapped between grains leading to hydrogen embrittlement.
Hydrogen embrittlement is not observed until the part is under load and can be avoided in several ways. The most obvious way is to ensure the designer has chosen steel with a tensile strength less than 170 ksi. These types of steels have grains large enough to allow escape of any trapped hydrogen. When it is necessary to galvanize high strength steel, a modified galvanizing process can be used to minimize the chances of hydrogen embrittlement. Rather than chemical cleaning the steel for the normal length of time, this modified process includes mechanically cleaning the steel, such as by blast cleaning, and then flash chemical cleaning (less than 30 seconds in the chemical cleaning bath) the steel. Flash chemical cleaning is necessary to remove any residues from the blasting operation. This reduces the amount of hydrogen the steel is exposed to and thus reduces the chances of hydrogen becoming trapped in the small grains of high strength steel.
