Great galvanized steel projects are built on teamwork: specifiers, steel producers, fabricators, and galvanizers all play a part in delivering durable, high-quality structures on schedule and within budget. One of the best places to start that collaboration is around steel chemistry, the most influential variable in the final appearance and thickness of a hot-dip galvanized (HDG) coating. Requesting strict limits on silicon levels in the steel is not recommended, but steel chemistry is still worth discussing early because it influences the appearance, thickness, and smoothness of the coating. Understanding its effects up front allows the project team to plan accordingly and keep expectations aligned. Where aesthetics are critical, the benefits of requesting steel chemistry that follows ASTM A385 recommendations may outweigh additional cost or lead time, and specialist advice on steel selection should be sought before fabrication.
Steel Chemistry and the HDG Coating
Silicon and phosphorus in steel influence how quickly iron and zinc react in the galvanizing kettle. Steels with levels outside the ranges described in ASTM A385 are often called “reactive steels,” and they tend to develop thicker, rougher, and sometimes more matte-gray coatings. Steels within those ranges tend to produce more consistent thickness and appearance. Some specifiers value reactive steels because the thicker coatings they produce can provide added corrosion protection and longevity. Others worry about the potential for very thick coatings, which can result in edge flaking during transport, handling, and erection, or can affect fit-up between parts. Fortunately, reactive steels are commonly galvanized, and thick coatings are readily managed with advance planning.
Learn about the Sandelin Curve
Strict Chemistry Limits
Steel mills frequently meet the chemistry ranges that work well for galvanizing. Requiring strict silicon or phosphorus limits in a project specification, however, can add cost and delay delivery. This is especially true for smaller orders that a fabricator purchases through a service center, where steel is typically sold to a standard specification that allows a broader silicon range.
AGA does not recommend that specifiers require strict steel chemistry limits for most projects except where elevated aesthetics are relevant. The silicon ranges recommended in ASTM A385 Section 3.2 are helpful targets and explain why galvanized steel varies in initial appearance, but they were never intended to serve as pass/fail criteria.
TABLE 1: RECOMMENDED ELEMENTAL COMPOSITIONS FOR HOT-DIP GALVANIZING (REF. ASTM A385 SECTION 3.2)
Element
Recommended % for HDG
Notes
Si
< 0.04 % or 0.15% - 0.22%
Sandelin steels and steels high in Si content may produce thick, matte, and/or rough coatings
P
< 0.04%
P > 0.04% produce rough, thick coatings susceptible to delamination
C
< 0.25%
Check ultimate tensile strength for steels >1% C
Mn
< 1.3%
High Mn may produce brownish colored and brittle coatings
For example, steels with 0.05% silicon or 0.23% silicon according to the Material Test Report (MTR) are not inherently problematic. Rather, reactivity increases as silicon moves away from the recommended ranges. Additionally, ASTM A385 Section 3.2 acknowledges MTRs are an imperfect basis for predicting how a given steel will react during hot-dip galvanizing. This means a specification that rejects material solely because an MTR reports a value marginally outside a recommended range may exclude steel that can be galvanized satisfactorily. A more practical approach is for specifiers to ask that the fabricator make a reasonable effort to follow the guidance in Section 3.2 of ASTM A385 where possible, and share the MTRs with the galvanizer so that everyone knows what to expect.
Design for HDG Already Accounts for Reactive Steels
Steel chemistry does not change how a structure should be designed for galvanizing. Typical HDG coating thickness, including the galvanizing of reactive steels, is already accounted for in the design of slip-critical connections, pins, clevises, hinges, expansion components, and more.
Best Practices: Communicate Early and Work Together
The most effective way to manage the effects of reactive steels is early collaboration between the fabricator and galvanizer. AGA suggests that specifiers encourage the following practices:
Share MTRs: Encourage fabricators to provide MTRs for all steel to be galvanized. Knowing the chemistry and configuration in advance lets the galvanizer anticipate coating behavior and discuss options with the fabricator before work begins. This is especially helpful for weathering steels, rolled shapes, fabrications with thick flanges or end plates, and fabrications that will be painted or powder coated after galvanizing.
Use galvanizing-friendly details: Whenever possible, design assemblies with similar material thicknesses and include well-planned venting and drainage. These details make it easier for the galvanizer to avoid excessively thick coatings.
Keep reactive steels in perspective: Thick coatings formed on reactive steels can occasionally flake at edges or corners when struck during handling, transport, or erection. While this can look concerning, it is easily repaired with allowable materials in accordance with ASTM A780 and does not compromise the long-term performance of the structure. Reactive steels and thick coatings are also more likely to have a mottled, mixed, dull, or rough appearance. This is a cosmetic characteristic and is not cause for rejection. Specifiers are encouraged to consider the intended use of the part and whether a thicker, rougher, duller coating matters for that application. For many parts, it is simply an aesthetic difference that has no bearing on corrosion protection.
    When Appearance and Chemistry Matter Most
    In some applications, the benefits of controlling steel chemistry for galvanizing outweigh the added cost and lead time. Examples include projects where appearance is a top priority, such as Architecturally Exposed Structural Steel (AESS) or galvanized fabrications that will be painted or powder coated. For these projects, specifiers should consider procuring steel with suitable chemistry per ASTM A385, which is often a worthwhile investment. AGA’s publications Design of Products to be Hot-Dip Galvanized After Fabrication, Hot-Dip Galvanized Architecturally Exposed Structural Steel (AESS) Guide, and Hot-Dip Galvanized Steel Bridge Design Guide offer more detailed guidance for projects requiring elevated aesthetics.
    Conclusion
    For most projects, specifiers do not need to impose strict silicon or phosphorus limits. A better path is to ask the fabricator to make a reasonable effort to follow ASTM A385, share MTRs with the galvanizer, apply sound design detailing practices, and keep reactive steels in perspective. For projects with elevated aesthetic requirements, specifying steel chemistry up front is often a worthwhile investment.
