Duplex Systems: Coating Galvanized Steel
The Duplex Systems: Coating Galvanized Steel seminar was developed by the American Galvanizers Association (AGA). This seminar introduces specifiers to the benefits of duplex systems as well as how to properly specify and design them. Though many specifiers are familiar with one type of corrosion protection or another, few realize the intrinsic value of utilizing two corrosion protection systems together, known as a duplex system. A duplex system is formed by painting or powder coating over hot-dip galvanized steel. When used together, the corrosion protection of the two systems combined is far superior to either protection system used independently.
The American Galvanizers Association (AGA) is a non-profit trade association dedicated to serving the needs of after-fabrication hot-dip galvanizers, fabricators, architects, engineers, and other specifiers. The AGA provides technical support on todays innovative applications and state-of-the-art technological developments in hot-dip galvanizing for corrosion control.
Continuing Education Credit
The AGA is a registered provider with the following agencies. Credit earned upon completion of the course and passing the test (requires 80% or better) will be reported only at your request (by providing your AIA/ACECnumber). This on-demand course is available for 1 hour of HSW credit.
American Institute of Architects
AIA/CES Policy on Endorsement: The following program is registered with the AIA/CES and does not include content that may be deemed or construed to be an approval, sponsorship, or endorsement of any material of construction or any method or manner of handling, using, distributing, or dealing in any material or product.
American Council of Engineering Companies
The American Galvanizers Association has met the standards and requirements of the Registered Continuing Education Program. Credit earned upon completion of this program will be reported to RCEP. A certificate of completion will be issued to each participant. As such, it does not include content that may be deemed or construed to be an approval or endorsement by ACEC or RCEP.
Purpose of the Seminar
The purpose of this seminar is to educate architects, engineers, and other specifiers about how to specify and design a successful duplex system of paint or powder coating over hot-dip galvanizing.
Learning Objectives
Upon completion of this course, you will be able to:
- Understand the hot-dip galvanizing process and coating benefits
- Identify the benefits of utilizing paint/powder coating with hot-dip galvanizing in a duplex system
- Recognize the importance of communication and clear assignments of responsibility in the specification of successful duplex systems
- Differentiate between HDG surface conditions in order to properly prepare the zinc coating for paint/powder
Revised in July 2020
