Aspinwall Water Treatment Plant
Pittsburgh, PA United States | 1989
The Sommerheim Water Treatment plant is an old, historic facility in an attractive building. The chlorine plant required security, but in a way that would preserve the beauty and aesthetic of the space. Known as WireWall, this high security fence has a fast-growing market in the interest of national security since 9/11.
Galvanized welded mesh was a cost-effective and attractive solution for a security fence. The superior durability of the hot-dip galvanized steel means the mesh will continue to guard this treatment facility without deterioration due to rust and corrosion. It can be difficult to produce a smooth, uniform, attractive finish, but special care and handling during the continuous hot-dip galvanizing process achieved the desired look.
Erie, PA United States
Aesthetics, Coating Durability, Corrosion Performance, Initial Cost, Quality of HDG
Welded security fence material.
HDG: 2
