LBT Inc. Structural Truck Frames
Omaha, NE United States | 2008
Warren Manufacturing is one of the largest manufacturers of bulk feed trailers, meaning their galvanized parts are seen all over the world. Since a large majority of their business travels through the northern United States and is plagued by road salts and moisture, the trailers needed a coating to protect them from harsh road conditions.
Hot-dip galvanized steel provided the best solution, allowing for a corrosion protection coating that would require no touch up or maintenance for years to come while providing durable barrier and cathodic protection against nicks and scratches. HDG steel also provides a more economical solution than other materials, has a low life cycle cost, and requires little to no maintenance throughout the life of the truck. These galvanized trucks will continue to transport feed safely and corrosion-free all over the world.
Birmingham, AL United States
Corrosion Performance
Suspension subframe, landing jack, and auger tubes.
