Franklin Park Conservatory Ameriflora
Columbus, OH United States | 1992
1992
The galvanizer worked with 70 tons (64 tonnes) of precisely fabricated support structure steel. The galvanized steel was uniquely coated with primer and painted with a moisture-cured urethane coating, extending the life of the structure. Holding 2,000 butterflies of over 200 species, the $15 million Butterfly Conservatory in Ontario is the focal point of a facility dedicated to the rearing of butterflies and the education and entertainment of the public.
The galvanized steel was uniquely coated with primer and painted with a moisture-cured urethane coating...
Over half a million people have enjoyed the tropical butterfly-haven since it's opening in mid-1997. Thanks to hot-dip galvanizing's low maintenance and long-lasting corrosion prevention, the Conservatory will be preserved for generations to come.
Niagara Falls, ON Canada
Quality of HDG
The entire steel support structure.
Yolles Partnership Toronto
M&G Steel
Baird/Sampson
