Blair Water Conditioning Inc. – Truck Bed Frames
Safety Harbor, FL United States | 2020
Packaged Cooling Systems specializes in the manufacturing of custom industrial refrigeration systems, primarily for use in the agriculture industry. The refrigeration system not only increases the shelf life of the product but will also expand the market to more distant locations. The racking and conveyor system allows for 16 large boxes of product to be transported in the Vacuum Coolers.
"Having many years of experience, we take pride in building quality products with quality equipment ensuring long life and dependable service for our customers. Hot-dip galvanizing helps us achieve this goal."
The steel fabricator and Vacuum Cooler manufacturer worked closely together to design the perfect rack and conveyor system for the cooling units. They both agreed galvanized steel was the preferred option as they wanted coating durability, corrosion performance and life cycle cost based on the wet, damp conditions regarding moisture. They consulted with a nearby galvanizer to assist in the finalization of the design in terms of size and weight. The galvanizing management team met with them to finalize venting & draining details especially regarding the way the racking system was to be hung and eventually hot-dip galvanized in the kettle.
The system has been a huge success. Choosing a galvanized system will allow Vacuum Coolers to have a safe working environment for years to come without worrying about the durability to the coating system.
Jacksonville, FL United States
Frame and rack made of tube steel and beams used to store and convey produce into and out of vacuum cooling units.
Steel: 30
HDG: 30
Packaged Cooling Systems, LLC
Latanick Equipment, Inc.
V&S Columbus Galvanizing
