Spruce River Dam controls levels and outflow from Anglin Lake in northern Saskatchewan, Canada. As part of a major structure overhaul and safety upgrade, the existing stoplog monorail system was replaced with a new hot-dip galvanized (HDG) monorail superstructure; new HDG stoplogs, lifting beam, and storage racking; new HDG hoist storage house superstructure; and other miscellaneous HDG site improvements such as new fencing and handrails.
Hot-dip galvanizing provides the Owner with a "do it once and forget about it" steel protection system.
Hot-dip galvanizing was chosen for its superior long-term durability and corrosion resistance in both wet and dry environments. Hot-dip galvanizing is also a forgiving system that is less prone to workmanship issues (such as flaws in coating systems) and works well with winter construction where ambient temperatures are too cold for site-applied finishes. It is also our opinion that a similarly performing coating system would be more expensive than hot-dip galvanizing to initially apply and would also require more periodic maintenance. Hot-dip galvanizing provides the Owner with a "do it once and forget about it" steel protection system.
Anglin Lake, SK Canada
Coating Durability, Corrosion Performance, Ease of Specifying, Initial Cost, Life-Cycle Cost, Prior HDG Experience, Quality of HDG, Turnaround Time
Hot dip galvanized components included: helical piles, stoplog monorail beam and superstructure, stoplogs, stoplog lifting beam, superstructure for hoist storage house, decorative railings on site, chain link fencing
Steel: 9
HDG: 9
Water Security Agency
Adam Brad Welding
General Contractor
Con-Tech General Contractors Ltd
Owner's Engineer
KGS Group Ltd.
AZZ Galvanizing - Saskatoon
