Iscar GSE Airport
Miami, FL United States | 2021
2022
Smith Transportation Equipment (STE) is the leading manufacturer of Airline Ground Support Equipment in the United States. STE was founded in 1994 and is located in Byhalia, MS, just 20 miles southeast of the Memphis International Airport. STE is dedicated solely to the design and manufacture of high lift vehicles for the airline industry. Their product line ranges from models to service Regional Jets to models designed specifically to accommodate high capacity aircraft, such as the Airbus A380.
“Hot -dip galvanizing is the only coating we can be sure will stand the test of time in the harsh airport environments our customers utilize our trucks in.”
Airline ground support truck platforms are galvanized. Since the hot-dip galvanized material in these platforms are in contact with dissimilar metals Smith Transportation worked closely with the galvanizer to identify areas and methods of creating barriers between dissimilar metals.
Byhalia, MS United States
Coating Durability, Corrosion Performance, Ease of Specifying
Trailers, Truck Beds, & Components
Steel: 2
HDG: 2
V&S Memphis Galvanizing LLC
