Stoughton Trailer Chassis
Waco, TX United States | 2021
Established in 1968, Linkletter’s Welding began building quality trailers that are designed for long life, hard use, and low maintenance. Being a Canadian manufacturer, Linkletter’s Welding can supply their products across North America. The trailers used in Canada and other snowy regions are exposed to moisture and road salts, which means corrosion is a real problem. Between the corrosion protection, low up-front cost, and long-term maintenance savings, they knew hot-dip galvanizing would be the perfect solution.
The owner, Wayne Linkletter takes great pride in providing the best quality trailer to his customers. This includes the ultimate corrosion protection. The company commutes to the galvanizer from more than ten hours away in order to provide the best quality hot-dip galvanizing for their trailer products.
Central Bedeque, PE Canada
Trailer Body Frame, Trailer Ramps, Fenders, Side rails, Dump door frames.
LWL Trailers
V&S Taunton Galvanizing LLC
