When it comes to transporting gas cylinders for medical, industrial and commercial use, Saf-T-Cart is the leader of the industry. Saf-T-Cart manufactures cylinder carts, cages, pallets, truck beds, and trailers for an extensive range of applications. The company operates in the city of Clarksdale in the Mississippi Delta.
We haven’t been able to find any other corrosion protection system that can stand up to the elements as well as hot dip galvanizing, and it’s maintenance free!
Saf-T-Cart started with a single product, but has since increased its line into a sixty-page catalogue of quality products that are sold throughout the United States and internationally.
The catalogue contains a wide selection of products including cylinder carts for oxygen, acetylene and medical products, cradles and pallets for gas distribution, storage stands and cages, running gear for moving welding and cutting equipment, trailers and truck beds for gas distributors, and an array of accessories and ancillary products.
The flatbed trailer made by patner Manac Trailer is a semi-trailer that is built for heavy hauling of gas products. Saf-T-Cart modified the manufactured frame into a customized trailer for hauling loads of gas cyclinder. Sold both domestically and internationally, these flatbed trailers have multiple galvanized components including the full length main frame, optional bulk head, , rear bumper, side rails, and cross members.
The Saf-T-Cart product line is immense, but the company’s top-selling product is its firewall cart. Companies in the manufacturing, construction, and industrial fields – where safety is a critical concern – are under constant review by the Occupational Safety and Health Administration (OSHA). One issue relevant to many Saf-T-Cart customers is that when oxygen or acetylene tanks are on a cylinder cart, they can fall under the rules same rules as when they are in storage. This means that they need to either be separated by twenty feet or a fire barrier. Saf-T-Cart’s firewall cart can store multiple tanks within OSHA regulations.
Saf-T-Cart knows that often times their products are exposed to the elements on jobsites, and may be located outside the building for manufacturing companies. That’s why they offer hot dip galvanized options for their most popular products. If not for hot dip galvanizing our customers would have to waist valuable time and money maintaining the products that are exposed to the elements.
Clarksdale, MS United States
Coating Durability, Corrosion Performance, Initial Cost, Life-Cycle Cost, Prior HDG Experience
Bottle Cages, Trailers, Truck Beds, & Components
        Steel: 14
        HDG: 14
Saf-T-Cart
        V&S Memphis Galvanizing LLC
