The quick turnaround of processing galvanized steel was crucial in the selection of galvanized steel, as well as the corrosion protection provided in this salt air environment. All the steel used for the box truss system was galvanized. The side panels are comprised of fabricated tubing of dimensions 50 ft. x 9 ft. (15m x 2.8m). All connections are galvanized A325 bolts. Cooperation between the designer, fabricator and galvanizer was crucial because of the progressive dipping requirement.
