North Carolina Research Campus Core Laboratory
Kannapolis, NC United States | 2007
The galvanized tubes and structural steel pieces are designed to hold the glass wall. This will be the focal point of the building. Because the pieces are erected in an atrium environment, moisture can be present, and thuse corrosion protection is important. The galvanized pieces were painted after galvanizing to match the decor of the building.
Southfield, MI United States
Coating Durability
All of the structure, and tubes.
        Steel: 75
        HDG: 75
        AZZ Metal Coatings
