Marine Mammal Center/New Balance Foundation
Boston, MA United States | 2009
L.A.Live! is a unique entertainment complex in Los Angeles sometimes referred to as "Times Square West." Inside this massive entertainment mecca is the mid-sized venue Nokia Center, among others.
The building plays host to many high profile events, including numerous concerts, comedy shows, award presentations, and television productions. The outer walls of the venue are used as an advertising source for the entertainment complex and the building itself. To hold the advertising signage, large frame structures were erected and line the outer walls of the structure. To maintain the durability of the frames hot-dip galvanizing was chosen to provide durability from corrosion protection.
Located just 12 miles from the Pacific Ocean, the pieces needed to be coated with HDG to lower maintenance and keep costs at a minimum to focus their energies on the structure for advertisement. Over 51 tons of steel were treated with HDG, including all the frame structures double-dipped to give all pieces excellent coverage against the corrosive elements of the atmosphere that will last for years, and keep the facility pumping in the glitz and glamour of Los Angeles downtown South Park neighborhood.
Los Angeles, CA United States
Corrosion Performance
Frame structures for holding building signage.
Steel: 52
HDG: 52
ELS Architecture
Washinton Iron Works
