SOHO Beach House Condominiums
Miami, FL United States | 2010
Highlighted in a bright aqua green, the Downtown Dadeland Residential Condominiums trellis is the centerpiece of the residences outdoor pool and patio area. A high chlorine and salt water atmosphere called for materials that could stand the test of time, as well as stand up to the elements-hot-dip galvanized steel is the perfect choice to satisfy both needs.
This trellis is seen by all visitors to the pool and viewed daily by condo owners through their windows, so aesthetic appearance was just as important as the ability to withstand corrosion. That also factored into the choice of HDG for the fact that it is easily painted to form an effective and visually appealing duplex system.
Galvanized steel can also easily be painted to enhance a structures appearance or follow branding or building color codes. Painted galvanized steel, called a duplex system, provides a further extended time-to first maintenance, making it the ideal choice to protect this at-risk, high-rise structure.
Corrosion Performance
Decorative trellis.
Steel: 30
HDG: 10
