Major upgrades to improve the operability and maintainability of Buffalo Pound Dam Control Structure required a coating that was durable, robust, resistant to wear and damage, and would last for a very long time. Hot-dip galvanizing was the obvious choice.
Hot-dip galvanizing's robustness and long-term durability offers an ideal "build it and forget about it" approach to corrosion resistance.
Buffalo Pound Dam forms Buffalo Pound Lake, the first major reservoir on the Qu'Appelle river system. While relatively small in size, this reservoir and dam is critical to the economy of Saskatchewan as it provides drinking water for a third of the Province's residents, supplies water to two significant potash mines, and supports recreation at numerous downstream Provincial and Regional parks.
The control structure is largely un-manned, with visiting Operators who check on reservoir and river conditions and adjust gate settings as required. These Operational teams do not have time or budget to maintain and touch-up coatings or address rust and corrosion. Hot-dip galvanizing's robustness and long-term durability offers an ideal "build it and forget about it" approach to corrosion resistance.
Additionally, the control structure steel sees a lot of abuse as Operators lift, move, place, and remove heavy steel stoplogs, bulkheads, and trash racks. Unlike paint and other top coat systems, hot-dip galvanizing stands up much better to bump and abrasion damage.
Moose Jaw, SK Canada
Coating Durability, Corrosion Performance, Ease of Specifying, Life-Cycle Cost, Prior HDG Experience, Quality of HDG
Except for a small amount of sheet piling, all steel utilized in this project was hot-dip galvanized. This included:
- Safety boom helical anchors
- Boom chain
- Monorail superstructure
- Decking, grating, and handrails
- Retrofit stoplog and bulkhead guides
- Trash racks, stoplogs, stoplog lifters, and bulkheads
- Log and bulkhead storage racking posts
- Monorail hoist storage doghouses
- Vehicle gates
- Cable tray
- Posts and framing for public safety signage
- Chain-link fencing
Steel: 85
HDG: 80
Hatch
WeldFab
Water Security Agency
General Contractor
Westridge Construction
Erector
Corbeau Welding & Fabrication
Owner's Engineer
KGS Group
AZZ Galvanizing - Saskatoon
