Wind Turbine
Valley, NE United States | 2001
Wind has been an energy source in the U.S. since the late 1800’s. In the last couple of decades we have seen wind farms emerge all across the United States as one of the fastest growing renewable energy sources. Since this inception one problem that has been consistent is corrosion. These platforms serve several functions from providing a safe platform to bolt sections of the tower together while erecting the turbines, to performing routine maintenance inside the towers. The galvanized platforms work well inside these turbine towers since it is not a climate controlled environment, preventing corrosion in some of the harshest conditions in the offshore turbines. Poinlosa Energy is a supplier of the internal tower platforms and parts for many of these large wind turbine manufacturers.
Proinlosa has been supplying high quality internal platforms, ladders, and parts for Wind Turbine companies such as Gamesa, Acciona, Alstom, and Vestas for over 10 years.
Hot-dip galvanizing is used in these turbine columns for corrosion protection.
Tropical Marine
Houston, TX United States
Bolt up platforms
Steel: 200
HDG: 200
Proinlosa Energy
Proinlosa Energy
AZZ Galvanizing - Houston
