Agritek Manufacturing Facility
Holland, MI United States | 2005
Gleaming in the sunlight behind a spray of decorative bushes, the heavy protective steel fence at the Rainbow Disposal Co was specifically designed to insure privacy and security for the overnight and long-term parking of the company's heavy-duty heavy-duty equipment.
The angle iron construction of the structure was created to withstand the abuse and aggressive handling associated with the business.  Hot-dip galvanized steel, which protects doubly with barrier as well as cathodic protection, will help the fence resist corrosion for decades of rough handling.  The metallurgical bonding of the zinc coating to the steel means the structure will be protected against the nicks and scratches that would cause paint coatings to crack and peel.  With 20.5 tons of galvanized steel, this fence will withstand the elements and hazards of its environment long into the future.
Tropical Marine
Huntington Beach, CA United States
Coating Durability
The entire perimeter fence and security gates.
        Steel: 20
        HDG: 20
Merit Steel and Supply
