Composting Hose Tractor Rehabilitation
Avonddale, PA United States | 2010
The Pro-Tote Bellway Wrecker Converter is a unique product that enables any fifth-wheel semi to be converted into a heavy duty wrecker. The complex fabrication and moving parts of this project made ensuring the complete coverage and movement of parts a considerable challenge during the galvanizing process.
Hot-dip galvanizing was the only corrosion-protection coating able to withstand the rugged outdoor use of this unit...
However, hot-dip galvanizing met the challenge, ensuring the duct will last for generations. Hot-dip galvanizing was the only corrosion-protection coating able to withstand the rugged outdoor use of this unit, including foul weather, road salts, and rough handling.
Many fleet owners are turning to Pro-Tote, which requires only a 5-minute installation. Installation of the galvanized heavy duty steel Pro-Tote is quick and easy, because the strength of the zinc coating protects the product from rust buildup caused by scratches or nicks made by chainware. The galvanized coating will protect this product, which is consistently exposed to environmental assaults and towing wear-and-tear well into the future.
South Bend, IN United States
Coating Durability
Entire wrecker converter unit.
Belleway Trucking Inc.
        AZZ Galvanizing - Plymouth
