Since its establishment in 1993, Lunmar Boat Lifts has been a trusted provider of high-quality boat lift solutions for fresh, brackish, and saltwater environments. Its commitment to excellence is reflected in the choice of a galvanized finish for all lift components, offering unparalleled protection against corrosion and ensuring a longer service life. This innovative approach not only reduces maintenance costs but also enhances safety by preventing structural failures caused by rust. Today, Lunmar’s products are relied upon along Gulf Coast waterways and marinas worldwide.
By leveraging the benefits of galvanized finishes, Lunmar has created a product line that withstands the rigors of marine exposure while addressing customer needs for durability, safety, and convenience.
Marine environments present unique challenges, with exposure to harsh elements above and below the waterline. Constant contact with moisture and fluctuating temperatures accelerates the potential for rust and corrosion, compromising the safety and durability of boat lift systems. Additionally, customers require solutions that enhance safety during watercraft access and use while offering a low-maintenance, long-lasting design.
Lunmar addresses these challenges through the design and manufacture of piling mount boat lift systems with a hot-dip galvanized finish. This protective coating creates a strong, anti-corrosive barrier that stands the test of time, even in the most demanding conditions. From cradle kits to low-profile solutions and sling kits, these galvanized lifts ensure reliable and safe watercraft storage and handling for a wide range of vessel sizes and types.
The piling mount lift systems are engineered for both durability and performance. The product lineup includes cradle kits with capacities ranging from 4,200 lbs to 10,000 lbs, featuring galvanized cradle beams, stainless steel cables, and piling mount brackets to ensure strength and stability. Low Profile Cradle Kits are designed for height-restricted environments, offering the same reliability while maintaining a streamlined, unobtrusive design. Sling Kits utilize weighted nylon slings to provide a flexible solution for lifting and securing watercraft, while specialized lifts such as the MiniMag 2800# and Magnum Side Mount Lifts cater to unique needs, such as narrow canals or smaller vessels, offering high-quality construction and ease of use.
The galvanized finish provides not only protection but also peace of mind, allowing customers to enjoy safer access to their watercraft with reduced risk of structural failure. The range of products includes not only boat lift components but also dock and gangway elements, delivering a comprehensive solution for marine infrastructure.
Lunmar’s piling mount boat lifts have earned a reputation for reliability and safety, becoming a preferred choice for customers worldwide. Their durable, low-maintenance design minimizes long-term costs while ensuring the integrity of critical components in challenging marine environments. With a focus on safety, quality, and customer satisfaction, Lunmar continues to set the standard for watercraft storage and handling solutions.
By leveraging the benefits of galvanized finishes, Lunmar has created a product line that withstands the rigors of marine exposure while addressing customer needs for durability, safety, and convenience. Whether along the Gulf Coast or in marinas around the world, these lifts deliver unmatched performance, making them an essential part of any watercraft owner’s experience.
Beaumont, TX United States
Lunmar sends over multiple different parts for their projects. Some of those parts include Cable Clamps, Cradle Beams, Overhead Beams, Strut Bars, I-Beams, pulleys, pilling mount, brackets, Dock mounts, Grading, Gangway's, and Guideposts.
Steel: 40
HDG: 40
Brandy Bertrand
Lunmar Boat Lifts
AZZ Galvanizing - Beaumont
