Keeyask Hydroelectric Generating Station
Keeyask, MB Canada | 2021
2022
The purpose of this project was to replace the existing 115kV delivery point single bay breaker station with a new four-bay 115kV breaker station and distribution substation. There is one outgoing transmission circuit and one 115kV circuit feeds the adjacent distribution substation. The Distribution substation was constructed with a single power transformer and eight distribution circuits in a circuit regulation configuration. The scope of work also included all high-side protective relaying and associated equipment. Construction was coordinated in a way to allow for continued transmission service from the existing 115kV structure until the new structure was commissioned.
Hot-dip galvanized steel provides long term protection to the steel both inside and out.
When it comes to which type of steel is use, hot-dip galvanized steel is used more in transmission structures and substations. One of the main reasons is because aesthetically, HDG steel “looks” better inside a substation and is maintenance free for years. Often times, these structures are in rural or difficult to access areas. Hot-dip galvanized steel provides long term protection to the steel both inside and out. The galvanizing plant was committed to twenty four hour turnaround on each load of this project in order to meet the stringent delivery timelines on the site.
Hope Mills, NC United States
Coating Durability, Corrosion Performance, Initial Cost, Life-Cycle Cost, Turnaround Time
H-Frames, A-Frames, Static Poles and Bus Supports for substation expansion project.
Steel: 30
HDG: 30
American Modular Power Solutions
ECE Power
V&S Amboy Galvanizing
