CPT Combination Pole Trailer
Manheim, PA United States | 2016
In the world of farm equipment this manufacturer is the leading supplier of farm equipment cutters and accessories. In 2006 the company was introduced to the process of galvanizing. After reviewing the many benefits of having their parts galvanized, they have now begun galvanizing all of the products they offer such as bale carriers, hay spears, pallet forks, tractor grapples, aerators, and box scrapers. In 2019 a total of 3,889,681 lbs. of steel was fabricated and ran through our facility.
Our Company is able to offer a 10 year limited warranty on deck rust thru on our products because of the benefits of galvanizing
The manufacturer of these products chose galvanizing as their standard coating due to the longevity and durability of the product. It Reduces maintenance cost and Improves safety by decreasing structural failures that can be caused by rust. Galvanizing increases the lifespan, unlike paint, they are naturally resistant to chemicals, abrasions, fertilizers, heat and moisture. Competitors typically use paint finishes on their products which cause more upkeep and more harm to the environment with paint chipping.
Due to products being used outdoors and exposed to the elements galvanizing protects the equipment which is a cost savings for their customers, not only monetary, but from a production standpoint from the lack of down-time due to not having to replace the equipment as often from structural failures. As a result, they are also able rise above their competition and offer a 10 year warranty on deck rust thru which is more advantageous and appealing to customers when comparing different manufactures and brands.
Beaumont, TX United States
90% of all manufactured components including: a frames, stiff arms, skids, body, t-shield, axles of bale carriers, hay spears, pallet forks, tractor grapples, Aerators, and box scrapers.
        Steel: 920
        HDG: 920
                                                    David Echol
                                                    Modern  AG Products
        AZZ Galvanizing - Beaumont
