Topple Tower Counter Weights
Niagra Falls, ON Canada | 2007
In the year 2000 when Landrys, Inc. purchased the Pleasure Pier in Galveston, Texas, hurricanes had left the park in shambles. When the time came to begin planning for renovations, the owners and designers were well aware of the harsh conditions the amusement park would encounter during its life-cycle. Among 16 major attractions, the Galaxy Wheel lies at the southern-most end of the pier, overlooking the Gulf of Mexico. The Galaxy Wheel is a 90-foot-high Ferris Wheel that can accommodate up to 160 children at a time.
...every piece of steel on the ride was galvanized.
Because of its location, as well as the obvious concern for rider safety, a duplex coating system was specified to protect the structure from the harsh marine environment and tropical weather of the Gulf Coast Region. If paint alone were used on the Galaxy Wheel, maintenance costs would be much higher, especially considering the rapid rate at which steel corrodes in coastal locations. Repainting the wheel would involve not only the direct labor and material costs, but also high shutdown costs as the ride would be out of commission. The synergistic effect of a duplex coating system will minimize the frequency at which these costs are incurred.
The high level of complexity of the wheel required a reliable and accessible line of communication be established among the designer, fabricator and galvanizer to ensure on-time delivery and high quality. The Galaxy Wheel is a large and complex structure with many parts very similar in design, and every piece of steel on the ride was galvanized. A strict inventory was maintained to ensure the parts were not delivered out of sequence, which would cause delays in painting and construction.
The Galaxy Wheel is a definite eye-catcher for Pleasure Pier, and its final appearance is a key element for the attraction. The utilization of a duplex coating system allowed the designers to choose the desired color scheme to highlight the ride while also benefitting from the protective qualities of the HDG coating. These factors provide a clear competitive edge over a paint-only coating and will result in less down-time due to maintenance requirements, as well as increased rider safety due to the preservation of the structural integrity of the steel components.
2012
Tropical Marine
Galveston, TX United States
Aesthetics, Coating Durability, Corrosion Performance, Life-Cycle Cost, Quality of HDG, Sustainability, Turnaround Time
Tubes, angles, brackets, and support tubes.
        Steel: 22
        HDG: 22
Landry's Pleasure Pier
Chance Rides
        AZZ Galvanizing - Chelsea
