City of Claremore Skate Park
Claremore, OK United States | 2008
The Corinne Jones Playground shading and seating structure, is a student project (Studio V) by the Clemson Architecture Center in Charleston, SC. The segmented concrete wall curves around the existing sidewalk, providing seating overlooking the playground. Ten wooden trusses are inserted between key blocks to create the shading and benches. The steel 2 x 2 louvers are tabbed and twisted 90° prior to being attached to the beam structure to create a unique twisted shading pattern above the poured concrete blocks and benches. Hot-dip galvanizing was the preferred coating system used for the steel portion of this project, due to the salt water environment in Charleston, SC. This very durable, corrosion protecting coating, allows for very limited maintenance in such climates.
2011
Civic Contribution
Charleston, SC United States
2" x 2" Angle
        Steel: 0.5
        HDG: 0.5
                                                    David Pastre
                                                    Clemlson Univeristy, City of Charleston, Charleston Parks Conservancy
