In the Appalachian Mountains of Virginia, coal mining has long been central to the culture and livelihood of the community. Over the past decade, many coal mines have closed due to green energy initiatives. However, one mine, the Buchanan Mine in Oakwood, Virginia, has remained open and thriving thanks to the type of coal it produces. Owned and operated by Coronado Coal Company, the mine specializes in metallurgical coal, or "met coal," a crucial ingredient in producing coal for steel manufacturing.
Hot-dip galvanizing was selected for its exceptional corrosion resistance and durability in the harsh conditions created by coal and its abrasive byproducts
Coal mines present an incredibly harsh environment for infrastructure and equipment. The constant exposure to moisture, coal dust, and abrasive byproducts accelerates wear and corrosion on steel structures. Additionally, the high humidity and temperature fluctuations underground amplify the challenges, leading to rapid material degradation without proper protection. This makes it critical to use materials and coatings that can withstand such conditions while maintaining performance over time.
Coronado Coal Company has invested heavily in upgrading and expanding the Buchanan Mine to ensure long-term production of met coal. Hot-dip galvanizing was selected for its exceptional corrosion resistance and durability in the harsh conditions created by coal and its abrasive byproducts. It has proven to be highly cost-effective for this application, offering superior longevity and minimizing the need for ongoing maintenance or replacements. Structures and equipment treated with galvanizing have consistently outperformed other coatings, resisting corrosion and deterioration more effectively.
For a recent conveyor upgrade, Coronado Coal Company worked with Peters Equipment Company to install a galvanized steel frame to move coal from the mine shafts to the scrubbers. This project required 15 tons of steel to be hot-dip galvanized, including frames, cross members, brackets, and hardware. Peters Equipment's project managers coordinated with the mine and galvanizer to ensure the steel was processed promptly, minimizing interruptions to the mine’s production schedule. The conveyor system was installed and operational within days of arriving on-site.
In such a demanding environment, where materials are constantly tested by moisture, abrasion, and corrosive elements, hot-dip galvanizing stands out as the ideal solution. Its unparalleled durability, cost-effectiveness, and ability to perform under extreme conditions make it indispensable for coal mining operations like those at Buchanan Mine. By choosing galvanized steel, Coronado Coal Company ensures their infrastructure remains reliable and resilient, allowing them to focus on efficient production and long-term success.
Industrial
Raven, VA United States
Beams, Frame cross members, brackets, plates and hardware
Steel: 17
HDG: 15
AZZ Galvanizing - Bristol
