Grays Harbor P.U.D.
Aberdeen, WA United States | 1998
The Scrubber conveyor projects were developed to move sludge from one area of the facility to another. The conveyor extends 1.5 miles over a natural wetland area, making corrosion protection of key importance to keep the facility running smoothly.
The life-cycle savings of using galvanized steel was a key influence...
This project was originally specified for a 3-coat paint system. After attending a Galvanize It! educational seminar, the spec was changed to hot-dip galvanizing for corrosion protection. 1900 tons of steel supports, frames, and conveyors were galvanized for this large and highly visible project. The life-cycle savings of using galvanized steel was a key influence, as the constant maintenance and upkeep of paint for corrosion protection increases life-cycle costs exponentially over the life of the project. Because galvanized steel is maintenance-free for 75+ years, your initial cost is the only cost for decades.
For elements of the structure that needed to be colored for safety reasons, a duplex system of paint over galvanized steel was chosen. A duplex system increases the maintenance-free life of a project 1.5 to 2 times, and even when the superficial paint layer begins to chip and peel, the zinc coating within will continue protecting the base steel for generations.
Cheswick, OH United States
Coating Durability, Corrosion Performance, Initial Cost, Prior HDG Experience
Conveyors, supports, frames
Louis Matustik
AEP
Ned Lust
Fairfield Engineering
V&S Columbus Galvanizing
