The SmogStop Barrier Project in Barrie, Ontario is a landmark North American installation – an innovative piece of highway infrastructure designed to do more than separate lanes. Brought to market by EKHO Infrastructure Solutions Inc., this post-and-panel system combines noise control with active air‑pollution mitigation in a single, unified structure.
SmogStop provides sunlight-powered air cleaning sustained by hot-dip galvanized steel posts.
On site, barrier wall panels drop into place between galvanized steel posts, supported by a unique structural framing system. Both panel types use hot-dip galvanized frames to deliver long-term durability, corrosion resistance, and reliable performance under the demanding conditions of a major provincial highway.
Each panel is a complex assembly of aluminum framing that houses photocatalytic-coated aluminum and acrylic elements. While aluminum naturally resists corrosion, the decision to specify hot-dip galvanized steel frames was critical: winter road salts and moisture, continuous UV, wind loading, and temperature swings demand a maintenance-minimized backbone. Hot-dip galvanizing delivers a robust, uniform coating that helps keep the framing structurally sound for decades.
As Canada accelerates long-term infrastructure investment, galvanizing becomes more than a specification, it becomes the system’s insurance policy for longevity and safety, and the platform for its environmental return. In Ontario’s harsh seasonal cycle, hot-dip galvanizing provides the durability and resilience needed to maximize SmogStop’s groundbreaking technology and positive environmental impact.
In total, 88 full-length (3,850 mm) SmogStop panels were manufactured and installed representing about 8,843 sq. ft. of panel area along Highway 400. The panels weigh approximately 84,000 lbs. (about 1,025 lbs. each on average) and are supported by 54 galvanized steel posts, enabling streamlined, drop-in-place installation built for continuous public-infrastructure performance.
Each panel’s double-walled design draws vehicle emissions into an internal channel, where airflow mixes pollutants and exposes them to a photocatalytic coating. Activated by sunlight, the coating breaks down NOx and VOCs into harmless byproducts—cleaning the air at the roadside with no moving parts and no added energy input. SmogStop signals a new generation of multifunctional infrastructure: practical, scalable, and designed for urban corridors facing air-quality and environmental challenges.
Hot-dip galvanizing extends service life and guarantees a stable framework so the SmogStop panels can perform throughout the system’s design life. As a durable, recyclable, and low-impact protective material, hot-dip galvanizing strengthens the project’s sustainability story and positions this Barrie installation as a model for future sustainable transportation infrastructure across Canada.
Excellence Award Winners
Transportation
Barrie, ON Canada
Structural Beams
Steel: 40
HDG: 40
Durisol
Ministry of Transportation of Ontario (MTO)
Durisol
AZZ Galvanizing - Acton
