Washington D.C. is set to welcome two new species to its community. The Smithsonian National Zoo has opened two new exhibits to accommodate a Canadian Lynx and a Bat-eared Fox. Their homes are located where the old bobcat exhibit was located, but not before some renovations were finished to create a space unique to each animal.
It was important to galvanize before painting, as these species are adept at climbing and may eventually scratch the paint.
The new exhibit is located with the other Great Cats exhibits. Because these two animals are smaller than their neighboring lions, the enclosure is smaller and not below grade. Guests can walk right up to the animals, almost an armlengths away. This intimate setting requires more of a structure than the “den” located across the pathway. The enclosure is surrounded with netting that is held up with galvanized and painted columns throughout the exbibit. The columns are round pipe with lifting points at the top to hold up the netting. Each pipe was galvanized then painted to blend in with the environment. It was important to galvanize before painting, as these species are adept at climbing and may eventually scratch the paint.
The fabricator, galvanizer, and painter each had proper communication to ensure this project was completed properly and on time. This new enclosure will stand the test of time, not only with the elements, but with the species that it holds. Both of these animals are new to the Smithsonian National Zoo and should entertain and educate visitors for years to come.
Washington, DC United States
Corrosion Performance, Life-Cycle Cost
Pipe Columns
HDG: 23
