Salt Water Filter Pod
Center, TX United States | 2011
Rarely is a more complex fabrication designed that also requires an outstanding corrosion resistant coating both internally and externally. The owners felt this complex fabrication had to have an extremely corrosion resistant coating due to its location in a coastal chemical plant. Multiple corrosive atmospheres could attack nearly every coating considered. These large Discharge silencers also had to have a corrosion resistant system that would provide a long corrosion free life. Hot-dip galvanizing was chosen as the best system. Internal baffles made coating with any other corrosion protection system nearly impossible. A full immersion dip in the galvanizing bath provided complete coverage at the most competitive price.
2014
Industrial
Koahsiung Sea Port, OH United States
Coating Durability, Corrosion Performance, Ease of Specifying, Prior HDG Experience
Three largal bafflese vessels with intern.
Steel: 7
HDG: 7
Steve McNeil
Penn Separator Corp
AZZ Galvanizing - Canton
