R.E. Campbell Wet Well Pipe
Three Rivers, NM United States | 2006
The Road Cross Water Ramp is a unique manifold designed by Rain for Rent is an alternative to a trench for water movement. The unit is placed in areas where uninterrupted flow of water is required and traffic needs to pass, but a trench is not a workable option. As Rain for Rent owns and operates the fleet of units and the final destination of the pieces is highly varied, they wanted to ensure they were built from the most cost effective and durable material available.
Hot-dip galvanized steel was specified to protect the vessels, flanges, split rings, and shims because of its long maintenance-free performance in varying environments. Hot-dip galvanizing is a total immersion process, and thus would fully coat and protect the inside of the equipment from fluids being contained and pumped through, while the external coating would resist the weathering elements. The complete coverage coupled with the maintenance-free nature of the coating lead to huge life-cycle cost savings for Rain for Rent. Thanks to hot-dip galvanized steel, these ramps will remain corrosion free and water flow will be uninterrupted wherever they are employed for decades.
Bakersfield, CA United States
The road cross water ramp, flanges, split rings, and shims.
        Steel: 150
        HDG: 150
Rain for Rent
Power Prime Pumps
        AZZ Galvanizing - Arizona
