Indianapolis Zoo Primate Cage
Indianapolis, IN United States | 2011
The Potawatomi Zoo in South Bend Indiana welcomed the arrival of the newest member of their extensive family, a white rhinoceros named Masamba. Having a white rhinoceros at the Potawatomi Zoo is a major accomplishment and shows how much the Zoo has evolved into a modern conservation and education facility. Since its humble start, the Potawatomi Zoo has become a premiere destination for fun and educational activity in the South Bend region.
By galvanizing all of this material, the enclosure will remain a modern, aesthetically pleasing area into the future.
Harsh winters, rainy seasons and the unpredictable nature of animals make for a challenge to create durable and aesthetically pleasing and safe enclosures. Due to the necessity of building a durable enclosure for the zoos most powerful species on site, the director, staff and volunteers worked together to comprise a design and a plan to ensure not only a durable enclosure for Masamba, but a safe and versatile environment where he could roam freely inside and outside of his building as weather allowed.
A full grown male can weigh 5,000 lbs. so a normal containment fence would not work. The Zoo staff knew that if they contracted this project out, they would never have the budget for it, so they took it on as a house project - with great success. This is very rare with zoos, due to the complexity of the design. The director designed the layout of how the stalls and chute should be built. He worked with a zoo volunteer, who had spent his career as a fabricator to consult on how it should be built and welded. The zoos in-house welders did all of the actual assembly and welding, which was managed by the zoos project manager. As pieces would get done, they would be brought to be galvanized over the course of the year, until the entire project was galvanized and pieced together perfectly, as evidenced in the photographs. It is extremely important to galvanize the fencing, enclosure and chutes to ensure there would never be rust. Rust is a USDA violation within animal containment. Paint is not a good option, because a rhinoceros rubs on the fence and would wear through the paint very quickly, exposing the steel to the elements, making it a constant battle to keep it painted and protected from rusting, not to mention the "call of nature" that can be very caustic to painted surfaces.
As an ambassador for his species, Masamba will help educate children and adults alike about rhino conservation and the ecosystem they call home in a worry-free, durable and aesthetically pleasing hot dip galvanized home for many years to come.
South Bend, IN United States
Frames, rails, tubes, bar weldments, tube frames, doors, hinges, plates, door frames, mesh, panels, angle weldments, square tubes, pipe weldments, pipe, gates, pins, channels, angles, frame weldments, triangular frames, rods, brackets
Steel: 13
HDG: 13
Josh Sisk - Director
Potawatomi Zoo
Josh Sisk
Potawatomi Zoo
Bob Urbanski
Potawatomi Zoo
Frank Thomas
Frank Thomas
AZZ Galvanizing - Plymouth
