Cross Oil Refinery
Smackover, AR United States | 2012
                                                     2013
        2013
This project is an excellent example of how galvanizing provides not only corrosion protection but also expedient service in quickly putting equipment online. Galvanizing was specified for this application to meet the short lead time requirement of the fabricator. If this equipment had been painted, additional time would have been required or extensive touch-up after assembly.
Galvanizing provides both outside and inside protection for hollow structures
Because the galvanizing process involves total immersion of the material, it is a complete process; all surfaces are coated. Galvanizing provides both outside and inside protection for hollow structures as well as complicated fabrications. Galvanizing continues at the factory under any weather or humidity condition and can be completed with short lead and turnaround times.
Industrial
Aztec, NM United States
Coating Durability, Corrosion Performance, Ease of Specifying, Prior HDG Experience, Quality of HDG
All surfaces.
William's Companies
Smithco Engineering
Metal Services
        AZZ Galvanizing - Rockford
