Butterfly Conservatory
Niagara Falls, ON Canada | 1997
1997
Located in Granville, IL, the Mid American Growers Greenhouse was a perfect candidate for the use of hot-dip galvanized steel. Since the plants grown in the greenhouse require routine watering, the tenacious, water-resistance coating that forms from the zinc patina protects the steel from the corrosive wet environment, as well as provides resistance to the dings and dents incurred during everyday work.
Galvanizing was also chosen because of its low life-cycle cost; the first cost is the last cost for projects utilizing HDG coating, providing the owner with no additional expenses for maintenance and upkeep. Since customers of greenhouses are often environmentally conscious, the galvanized coating was the perfect choice because of its 100% recyclability, making this an earth friendly solution for corrosion protection. The clean, sharp appearance of the HDG coating was a compliment to the colorful plant life in the green house, making the plants stand out and appeal more to customers.
The manufacturer firmly believes HDG steel sets them apart from the competition. The optimum corrosion protection offered by hot-dip galvanizing provides a critical advantage over any other maintenance intense options utilized by competitors. In spite of the daily grind of exposure to forklifts, pallets, or chemicals, Mid American Growers will enjoy a facility that is safe, bright, cost effective, and corrosion free for decades.
Food & Agriculture
Granville, IL United States
Structural columns, braces, tubular shapes and brackets.
Steel: 4.65
HDG: 3.85
Cherry Creek Systems
AZZ Galvanizing - Denver
