Calipso Water Park
Limonges, ON Canada | 2009
                                                     2009
        2009
Car-wash equipment is subjected to one of the most hostile environments that can be created. The equipment is called upon to be operational at a moments notice, and with the exception of freezing weather, anytime automobiles are on the road. A car-wash is a revenue-producing piece of equipment so any downtime means losing potential revenue. A profitable car-wash will be called into action over 50 times per day so any corrosion would inhibit its performance.
Hot-dip galvanized (HDG) steel provides the durability to meet the task.
Hot-dip galvanized (HDG) steel provides the durability to meet the task. The appearance of the facility is an important marketing consideration. HDG provided an attractive aesthetic look as well as protection. The option for corrosion protection being stainless steel, HDG was the wise choice initially and considering the life-cycle cost, it is the most cost effective method of corrosion protection. HDG component are durable, cost less, last longer and look good for generations.
2011
Arvada, CO United States
tubular beams, columns, equipment and instrument boxes and smaller components.
WashTec AG
MarkVII Engineering
        AZZ Galvanizing - Denver
