Offshore drilling’s most persistent hazards is the dropped object: heavyweight drill collars and drill pipe falling without warning. Loads can exceed 27,000 pounds – and when dropped from nearly 100 feet, can unleash more than 2.6 million pounds of force. To address this ongoing challenge, the Impact Attenuating Media Weldment Assembly was developed to absorb extreme energy and protect workers, equipment, and deck structures.
Offshore is unforgiving but hot-dip galvanizing is unrelenting.
Engineered by NOV and fabricated by Triple C Industries, this safety-critical device is deployed to one of the harshest environments – saltwater, humidity, UV exposure, and constant abrasion. From the outset, the team specified hot-dip galvanizing for one clear reason: a coating system tough enough to keep performing offshore in corrosive conditions, with a long service life before first maintenance.
Hot-dip galvanizing delivers corrosion protection through metallurgically bonded zinc–iron alloy layers that provide both barrier and cathodic protection. That durability matters here: the assembly sits partially enclosed inside another steel pipe, where moisture can linger and abrasion is unavoidable. In such conditions, coatings like paint and many epoxies are more vulnerable to chipping and wear – damage that can expose steel, accelerate corrosion, and lead to potential catastrophic failures.
Offshore, maintenance is never simple – access is limited, recoating is costly, and delays ripple across operations. Galvanizing helps remove that burden by reducing the need for future recoats and repairs supporting safer rigs, fewer interruptions, and instilling confidence that essential jobs can continue without essential systems failing.
The galvanizer brought process expertise confirming venting, drainage, and detailing so zinc could reach critical cracks and crevices. Working in lockstep with the fabricator, the team resolved issues early, adapted to changes, and met tight deadlines. Large-kettle capacity also allowed major pieces to be dipped once, supporting consistent, high-quality coverage across the assembly.
A rare intersection of engineering discipline, safety innovation, and offshore performance, the Impact Attenuating Media Weldment Assembly is built to serve for 50-100 years. It stands as a reminder that the most important advances aren’t always visible – sometimes they are hidden systems that hold the line when everything else goes wrong.
Excellence Award Winners
Tropical Marine
Houston, TX United States
All surfaces were HDG, entire Impact Media Weldment
Steel: 2
HDG: 2
John Wissing
NOV
Matt Wissing
NOV
Chris Carlton
Triple C Industries
Valmont Coatings - United Galvanizing
