Harley Davidson of the Woodlands
The Woodlands, TX United States | 2004
The design of the Hummer dealership called for exposed steel on both the inside and outside of the building. The original specification was for painted steel; however, the architect felt galvanizing was a great fit for the application and changed the spec. In addition to having a few prior bad experiences, the architect thought galvanized steel more closely suited the military-style, industrial vehicle. Unsightly corrosion or constant maintenance would not suit the luxury dealership, and by specifying hot-dip galvanized steel the architect was able to ensure the project would look the same in 50 years as the day it opened.
Allentown, PA United States
Aesthetics, Prior HDG Experience, Turnaround Time
Frames, beams, angles, lentils, and miscellaneous steel.
        Steel: 20
        HDG: 20
Infrastructure Incorporated
Pany & Lentz
        V&S Lebanon Galvanizing
