Boat Ramp Pier
Pittsburg, TX United States | 2011
Floating Docks rub and bump together, they are in the water environment and exist in a variety of weather conditions. Galvanizing has been proven to be the best corrosion protection in these environments. Complex structures are expensive to paint and even more expensive to repaint. Initial cost and life cycle cost analysis both show hdg as the clear choice. HDG is the industry standard for floating docks nationwide.
2011
Lakefront, WV United States
Coating Durability, Corrosion Performance, Ease of Specifying, Life-Cycle Cost, Prior HDG Experience, Quality of HDG
All frames, connections, supports and accessories are galvanized.
        Steel: 50
        HDG: 50
                                                    John Meriweather
                                                    Merco Marine
                                                    John Meriweather
                                                    Merco Marine
        AZZ Metal Coatings
