2512 Underwater Pipe Carrier
Omaha, NE United States | 2021
2022
In the world of farm equipment this manufacturer is the leading supplier of farm equipment, cutters, and accessories. In 2006 the company was introduced to the process of hot-dip galvanizing. After reviewing the many benefits of having their parts galvanized, they have now begun hot-dip galvanizing all the products they offer. In 2021 a total of 4,500,000 lbs. of steel was fabricated and ran through the galvanizers facility.
Galvanizing reduces maintenance cost and improves safety by decreasing structural failure that is caused by rust.
The manufacturer of the products chose hot-dip galvanizing as their standard coating due to the longevity and durability of the product. It reduces maintenance cost and improves safety by decreasing structural failure that can be caused by rust. Hot-dip galvanizing increased the lifespan of their products, unlike paint, they are naturally resistant to chemicals, abrasions, fertilizers, heat, and moisture. Competitors typically use paint finishes on their products which causes more upkeep and more harm to the environment with paint chipping. Due to products being exposed to the elements, HDG protects the equipment, which helps increase the savings to their customers so they do not need to replace the equipment as often. They are also able to rise above their competition and offer a 10-year warranty on deck rust which is more appealing to customers when comparing to different manufactures and brands.
Beaumont, TX United States
The fabricator of this material offers many different options in their line-up of cutters and accessories. An example of the parts and pieces galvanized are the A frames, stiff arms, skids, the body, t-shields, and axels. They also offer bale carriers, hay spears, pallet forks, tractor grapples, aerators, and box scrapers.
AZZ Galvanizing - Beaumont
