Absolutely Fabulous Gateway Arch
Springfield, MA United States | 2011
Though heavy fog and humidity are common in this coastal area, 35,000 tons of hot-dip galvanized steel will prevent this structure from surface corrosion. The Crown, part of the San Diego skyline, is highly visible from approaching airlines landing at a nearby airport. The developer was interested in attractive modern style with low maintenance.
Select Environment
San Diego, CA United States
Corrosion Performance
Tubular structural steel, tubulars, wire mesh
        Steel: 18
        HDG: 18
Whitmore Steel, Inc.
        AZZ Metal Coatings
