At a modern grain facility, much of the work happens well above ground. Conveyors move grain between storage structures, bucket elevators carry material vertically, and critical equipment may sit dozens of feet above the facility floor. Connecting it all is an infrastructure that is easy to overlook but essential to keeping the operation accessible, safe and productive.
From an individual installation in Sauk City to agricultural facilities around the world, hot-dip galvanizing provides the long-term corrosion protection needed to keep that critical infrastructure performing season after season.
Chief Agri's catwalk and tower systems create that connection. Engineered for grain storage and handling operations, the systems provide structural support for elevated equipment while giving personnel access for inspection, maintenance and everyday operation. Catwalks can be configured in multiple widths and lengths with center walkways, dual walkways and walk-around platforms, while supporting towers can incorporate ladders, cages, internal platforms and other access configurations. Their modular design allows the systems to be adapted to a wide variety of facilities and even integrated with grain-handling equipment from other manufacturers. A grain-handling installation in Sauk City, Wisconsin, illustrates how these systems become part of the infrastructure supporting modern agricultural operations. The galvanized steel catwalks and supporting structures provide elevated connections within the facility, demonstrating how Chief's engineered components can be integrated into a larger grain-handling environment. While the installation represents just one application, it reflects the broader need for dependable, accessible infrastructure across the agricultural industry. That versatility places the steel in a demanding environment. In agricultural regions such as southern Wisconsin, freezing winters, seasonal precipitation and fluctuating temperatures create challenging conditions for exposed steel structures. Catwalks and towers spend their service lives outdoors, elevated above the ground and continually exposed to the elements. Combined with the dust and debris associated with grain-handling operations, these conditions make long-term corrosion protection an important part of the design. Chief addresses that challenge by specifying hot-dip galvanizing throughout its catwalk and tower systems. The coating protects the square tubing, angle iron and other structural components that form the system while providing the durability needed for equipment intended to remain in service for decades with minimal maintenance. This is especially valuable for elevated structures, where future surface preparation, painting and coating maintenance could be difficult, disruptive and costly. For facilities such as the installation in Sauk City, reducing these maintenance demands helps protect the long-term value of infrastructure that plays an essential role in daily operations. Hot-dip galvanizing also complements the way Chief designs its systems. Components are engineered around a largely bolt-together assembly that minimizes field welding and simplifies installation. Structural members can therefore arrive at the jobsite already protected and ready for assembly, allowing corrosion protection to become an integral part of the manufactured system rather than another operation that must be completed in the field. For the galvanizer, these structures present their own set of considerations. Long structural sections, fabricated trusses and hollow square tubing require careful attention to handling as well as proper venting and drainage to promote complete coating coverage and efficient processing. The result is corrosion protection capable of reaching the exposed surfaces, connections and complex geometries found throughout the finished assemblies. The significance extends beyond any single grain facility. Chief introduced its catwalk and tower systems more than a decade ago as part of a broader line of grain storage and handling equipment serving agricultural operations around the world. By making hot-dip galvanizing a standard feature of these systems, Chief demonstrates how galvanized steel can be incorporated into manufactured agricultural infrastructure as part of the original product design. Once installed, the catwalks may fade into the background of a much larger grain operation. Yet every day they support equipment, provide access and connect the systems responsible for moving and protecting the harvest. From an individual installation in Sauk City to agricultural facilities around the world, hot-dip galvanizing provides the long-term corrosion protection needed to keep that critical infrastructure performing season after season.
Food & Agriculture
Industrial
Sauk City, WI United States
Coating Durability, Corrosion Performance, Ease of Specifying, Life-Cycle Cost, Prior HDG Experience, Quality of HDG, Sustainability, Turnaround Time
Center walkways, dual walkways, walk-around platforms, supporting towers, ladders, cages, internal platforms
Steel: 25
HDG: 25
