Blough Avenue Bridge
Navarre, OH United States | 1997
1997
A low clearance bridge is susceptible to flowing water and floating debris. Durable galvanized coatings ensure a long life in a hostile environment. Having used hot-dip galvanizing (HDG) many times before, the specification was easy to write and the successful corrosion resistant results were guaranteed. Life-cycle cost was a major consideration since the county inspects and maintains their own bridges.
2011
Canton, OH United States
Coating Durability, Corrosion Performance, Ease of Specifying, Life-Cycle Cost, Prior HDG Experience, Quality of HDG, Sustainability
Long beams with camber, cross beams and connection angles, guiderail and posts
Steel: 46
HDG: 46
Stark County Ohio
Scott Basinger
Stark County Ohio
AZZ Galvanizing - Canton
