The swing-set at the Pro Sanctity Center, a Catholic youth retreat just north of Elkhorn, Nebraska, was created as a part of a Boy Scout Eagle Project. The Pro Sanctity Center needed strong, safe playground equipment since the current equipment had become worn down and unsafe.
Galvanizing the structure was the clear solution for these needs...
The designer needed a quick turnaround time in order to complete the project on time, besides wanting to create a structure that would require no future maintenance and repairs. Galvanizing the structure was the clear solution for these needs, as the galvanized zinc coating provides a uniform, safe, and durable coating, allowing it to last decades longer than any other available option. The galvanizing process is also very simple, allowing for a quick turn-around time. The resulting structure, which is 10 feet high, 30 feet long and capable of holding 6 swings, will be sure to provide joyful entertainment to children for many years to come.
Elkhorn, NE United States
Initial Cost, Life-Cycle Cost, Sustainability
All of the swing-set components.
Steel: .5
HDG: .5
Jacob Benes
