Rejects on Site
My customer just rejected a load of rebar at the job site, is this right?
If your customer rejected the rebar in the field, he was incorrect. According to ASTM A767 section 8.2, "The material shall be inspected at the galvanizer's plant prior to shipment. "You must provide access for inspection at your plant, and the customer must inspect it there." He may take the samples for testing elsewhere.
